Saltar al contenido principal
Bose Solo 5 Sound Bar Control Panel Replacement
Qué necesitas
  1. Bose Solo 5 Sound Bar Control Panel Replacement, Control Panel: paso 1, imagen 1 de 1
    • Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
  2. Bose Solo 5 Sound Bar Control Panel Replacement: paso 2, imagen 1 de 2 Bose Solo 5 Sound Bar Control Panel Replacement: paso 2, imagen 2 de 2
    • Remove the five 18.25mm screws with the Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Control Panel Replacement: paso 3, imagen 1 de 1
    • Remove the gold plates snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Control Panel Replacement: paso 4, imagen 1 de 1
    • Using the plastic opening tool, lift the circuit board up and remove from housing.
  5. Bose Solo 5 Sound Bar Control Panel Replacement: paso 5, imagen 1 de 2 Bose Solo 5 Sound Bar Control Panel Replacement: paso 5, imagen 2 de 2
    • Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
Conclusión
Una persona más ha completado esta guía.
Emma
Miembro Desde 10/05/18
500 Reputación
3 Guías creadas
5 comentarios
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
Tyler Barney - Contestar
hallo und wo bekomme ich das Ersatzteil die Platiene 73252 Delta 3
APP TISCHNER - Contestar
Has anyone had any luck finding the same board. Im looking.
ka.wells - Contestar
I know how to open it. What I don't know is where to buy one.
szanti - Contestar
If anyone was able to find the board, it wuold be great to know where did you find it. Looking for this board during months...
Juan Ramirez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 106
Todo El Tiempo: 12,800
