Introducción
Use this guide to replace the gearbox in the Bosch PS21. If the clutch is not working, the gearbox will need to be replaced. Be sure to remove the battery before disassembling the device.
Qué necesitas
Pinch the two release tabs on the sides of the battery, and slide the battery out.
Locate the clip that binds the two halves of the outer casing together on the rear edge of the battery shaft. Remove the clip with the angled tweezers.
Una persona más ha completado esta guía.
