Saltar al contenido principal
Bosch MFQ 36440 Disassembly
Qué necesitas
  1. Bosch MFQ 36440 Disassembly, Remove screws: paso 1, imagen 1 de 1
    • Remove 2x Torx screws (size 10) on the front
  2. Bosch MFQ 36440 Disassembly, Remove the grey front cover: paso 2, imagen 1 de 2 Bosch MFQ 36440 Disassembly, Remove the grey front cover: paso 2, imagen 2 de 2
    • Remove the front cover
    • Gently push downwards the cover, then pull it through the holes
    • Once it is detached at the top, slide the entire gray cover down
  3. Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: paso 3, imagen 1 de 3 Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: paso 3, imagen 2 de 3 Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: paso 3, imagen 3 de 3
    • The first step is somewhat tricky. Use a long screwdriver to release the first part at the top.
    • Continue your way all around the case.
    • The clip on top front is tricky a long and thin flat screwdriver is needed
    • The clip on very top is impossible to release you need to pry the two half’s carefully apart until the top releases
  4. Bosch MFQ 36440 Disassembly, Assembly: paso 4, imagen 1 de 2 Bosch MFQ 36440 Disassembly, Assembly: paso 4, imagen 2 de 2
    • Prop everything back into the half without the clips
    • Take care about the safety cam to be aligned in the cover
Conclusión
6 personas más completaron esta guía.
Stanky
Miembro Desde 07/08/17
1,268 Reputación
6 Guías creadas
2 comentarios
Hey, so what does “Continue your way all around the case” mean? I got the one clip open which you pictured, and then I got the case open just a tiny bit more, but now I’m stuck.
Could someone perhaps detail the last steps more? :(
Carsten Hagemann - Contestar
When you put it together again use the side with the cable “channels”, it is way easier than with the other side.
Tobias Vdb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 27
Ultimos 30 días: 153
Todo El Tiempo: 8,689
