Saltar al contenido principal
Boosted Mini Belt Replacement
Qué necesitas
  1. Boosted Mini Belt Replacement, Belt: paso 1, imagen 1 de 2 Boosted Mini Belt Replacement, Belt: paso 1, imagen 2 de 2
    • Unscrew the axle nut holding the wheel in place with your wrench on the side of the board where the belt has snapped/became worn.
  2. Boosted Mini Belt Replacement: paso 2, imagen 1 de 2 Boosted Mini Belt Replacement: paso 2, imagen 2 de 2
    • Take off the nut and the washer.
  3. Boosted Mini Belt Replacement: paso 3, imagen 1 de 3 Boosted Mini Belt Replacement: paso 3, imagen 2 de 3 Boosted Mini Belt Replacement: paso 3, imagen 3 de 3
    • Use your allen wrench to remove the two black motor cap screws on the motor counter clockwise.
  4. Boosted Mini Belt Replacement: paso 4, imagen 1 de 1
    • Remove the plastic motor cap.
  5. Boosted Mini Belt Replacement: paso 5, imagen 1 de 3 Boosted Mini Belt Replacement: paso 5, imagen 2 de 3 Boosted Mini Belt Replacement: paso 5, imagen 3 de 3
    • Use your allen wrench to loosen the four motor screws on the motor by turning your tool ¼ turn left. The motor should be loose.
  6. Boosted Mini Belt Replacement: paso 6, imagen 1 de 3 Boosted Mini Belt Replacement: paso 6, imagen 2 de 3 Boosted Mini Belt Replacement: paso 6, imagen 3 de 3
    • Remove the wheel and belt (if not snapped off already).
  7. Boosted Mini Belt Replacement: paso 7, imagen 1 de 2 Boosted Mini Belt Replacement: paso 7, imagen 2 de 2
    • Make sure the axle spacer and drive pulley washer are still in place on the axel.
  8. Boosted Mini Belt Replacement: paso 8, imagen 1 de 3 Boosted Mini Belt Replacement: paso 8, imagen 2 de 3 Boosted Mini Belt Replacement: paso 8, imagen 3 de 3
    • Get your new Boosted belt and place it on the inner side drive pulley of the wheel.
  9. Boosted Mini Belt Replacement: paso 9, imagen 1 de 2 Boosted Mini Belt Replacement: paso 9, imagen 2 de 2
    • Place the wheel with its new belt inner side first on the axle, making sure the belt is securely back over the motor pulley.
  10. Boosted Mini Belt Replacement: paso 10, imagen 1 de 1
    • To tighten the belt, create tension by putting your thumb on the wheel of the board and your fingers on the motor and pull the motor towards the motor driver until the belt is taught.
  11. Boosted Mini Belt Replacement: paso 11, imagen 1 de 2 Boosted Mini Belt Replacement: paso 11, imagen 2 de 2
    • Using the allen wrench place the two screws furthest from the wheel first back in place and tighten, then tighten the closer two screws.
  12. Boosted Mini Belt Replacement: paso 12, imagen 1 de 3 Boosted Mini Belt Replacement: paso 12, imagen 2 de 3 Boosted Mini Belt Replacement: paso 12, imagen 3 de 3
    • Place the axle washer and nut back on the axle.
    • Make sure that the axle washer is first, closest to the wheel, then the nut.
  13. Boosted Mini Belt Replacement: paso 13, imagen 1 de 1
    • Use your wrench to turn the nut clockwise to tighten it.
  14. Boosted Mini Belt Replacement: paso 14, imagen 1 de 1
    • Place the plastic motor cap on the motor.
  15. Boosted Mini Belt Replacement: paso 15, imagen 1 de 3 Boosted Mini Belt Replacement: paso 15, imagen 2 de 3 Boosted Mini Belt Replacement: paso 15, imagen 3 de 3
    • Lastly, use the allen wrench to reinstall the two motor cap screws.
Conclusión
If the belt on the other side of the skateboard also needs to be replaced, repeat steps 1-16.
Una persona más ha completado esta guía.
Juliana Renert
Miembro Desde 02/02/24
241 Reputación
1 Guía escrita
Equipo
UC Davis, Team 4-1, Andersen Winter 2024 Miembro de UC Davis, Team 4-1, Andersen Winter 2024
UCD-ANDERSEN-W24S4G1
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 84
