Saltar al contenido principal
Boosted Board 1st Generation Skateboard Bearings Replacement
Qué necesitas
  1. Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: paso 1, imagen 1 de 2 Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: paso 1, imagen 2 de 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Skateboard Bearings Replacement: paso 2, imagen 1 de 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Skateboard Bearings Replacement: paso 3, imagen 1 de 2 Boosted Board 1st Generation Skateboard Bearings Replacement: paso 3, imagen 2 de 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Skateboard Bearings Replacement: paso 4, imagen 1 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: paso 4, imagen 2 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: paso 4, imagen 3 de 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: paso 5, imagen 1 de 2 Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: paso 5, imagen 2 de 2
    • Use one finger to pull out the pulley bearing.
    • A good technique is to go around in a circle and lift from underneath the bearing in a carving motion.
  6. Boosted Board 1st Generation Skateboard Bearings Replacement: paso 6, imagen 1 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: paso 6, imagen 2 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: paso 6, imagen 3 de 3
    • Use an Allen wrench to apply pressure to the inside edge of the bearing until it pops out
  7. Boosted Board 1st Generation Skateboard Bearings Replacement: paso 7, imagen 1 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: paso 7, imagen 2 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: paso 7, imagen 3 de 3
    • Replace bearing by dropping it in the center of the wheel and use a socket wrench to pop in back it place
  8. Boosted Board 1st Generation Skateboard Bearings Replacement: paso 8, imagen 1 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: paso 8, imagen 2 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: paso 8, imagen 3 de 3
    • Slide the bearing spacer on to an Allen wrench
    • Align the Allen wrench in the center of the bearing and drop the spacer directly in the middle
    • Repeat Step 7 for placing the bearing in this side of the wheel.
Conclusión
To reassemble your device, follow these directions in reverse order.
Una persona más ha completado esta guía.
Emily Imfeld
Miembro Desde 10/06/16
532 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 15-7, Livingston Fall 2016 Miembro de Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 763
