Saltar al contenido principal
Boosted Board 1st Generation Remote Battery Replacement
Qué necesitas
  1. Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: paso 1, imagen 1 de 3 Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: paso 1, imagen 2 de 3 Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: paso 1, imagen 3 de 3
    • Before disassembling your remote, be sure it is powered off.
    • Remove the four 17.57mm screws from the bottom of the case with a PH0 screwdriver.
  2. Boosted Board 1st Generation Remote Battery Replacement: paso 2, imagen 1 de 2 Boosted Board 1st Generation Remote Battery Replacement: paso 2, imagen 2 de 2
    • Carefully separate the two halves of the casing by pulling them apart at the seam.
    • Be sure to keep the scroll wheel, lever and buttons attached to the housing.
  3. Boosted Board 1st Generation Remote Battery Replacement: paso 3, imagen 1 de 3 Boosted Board 1st Generation Remote Battery Replacement: paso 3, imagen 2 de 3 Boosted Board 1st Generation Remote Battery Replacement: paso 3, imagen 3 de 3
    • Remove the rectangular black adhesive foam on top of the battery by peeling it away from the battery.
    • Desolder the battery connections from the circuit board.
    • Replace the dead battery with a new 3.7 volt lithium polymer battery.
    • Refer here for more information how to desolder the battery.
Conclusión
3 personas más completaron esta guía.
Kevin Manko
Miembro Desde 10/06/16
164 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-7, Livingston Fall 2016 Miembro de Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Miembros
6 Guías creadas
4 comentarios
Where can I get the battery? Or can you give specs? Thanks!
Dan Davie - Contestar
hi my name is Eugene.  I have a question .  My skateboard remote is gone.  remotes are not sold in my country.  what should i do how can i use the skateboard .  we sell remotes from another company.  how can it be adjusted to my boosted mini .  help me solve the issue please
Evgeny Bubnov - Contestar
You can't use 3rd party remotes with proprietary Boosted products.
Tom Tamaira -
Verified this works with V2 and V3 remotes as well. I did a R29 and it works great. Thank you for the info.
Thayne Christiansen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 53
Todo El Tiempo: 4,772
