Saltar al contenido principal
Boosted Board 1st Generation Rear Wheels Replacement
Qué necesitas
  1. Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: paso 1, imagen 1 de 2 Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: paso 1, imagen 2 de 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Rear Wheels Replacement: paso 2, imagen 1 de 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Rear Wheels Replacement: paso 3, imagen 1 de 2 Boosted Board 1st Generation Rear Wheels Replacement: paso 3, imagen 2 de 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Rear Wheels Replacement: paso 4, imagen 1 de 3 Boosted Board 1st Generation Rear Wheels Replacement: paso 4, imagen 2 de 3 Boosted Board 1st Generation Rear Wheels Replacement: paso 4, imagen 3 de 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
Conclusión
Emily Imfeld
Miembro Desde 10/06/16
532 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 15-7, Livingston Fall 2016 Miembro de Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,294
