Saltar al contenido principal
Boombotix Boombot Mini Speaker Replacement
Qué necesitas
  1. Boombotix Boombot Mini Speaker Replacement, Speaker: paso 1, imagen 1 de 3 Boombotix Boombot Mini Speaker Replacement, Speaker: paso 1, imagen 2 de 3 Boombotix Boombot Mini Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Twist the front panel of the speaker to the left.
    • Do not try to pry or pop off the front panel.
  2. Boombotix Boombot Mini Speaker Replacement: paso 2, imagen 1 de 3 Boombotix Boombot Mini Speaker Replacement: paso 2, imagen 2 de 3 Boombotix Boombot Mini Speaker Replacement: paso 2, imagen 3 de 3
    • Take out the four screws, then remove the panel that contains the speaker.
  3. Boombotix Boombot Mini Speaker Replacement: paso 3, imagen 1 de 3 Boombotix Boombot Mini Speaker Replacement: paso 3, imagen 2 de 3 Boombotix Boombot Mini Speaker Replacement: paso 3, imagen 3 de 3
    • Take the speaker off of the base.
    • Expose the motherboard and place the speaker next to it.
    • Be careful not to tangle or damage the wires connecting the speaker.
    • This panel will be harder to get off. Use something small such as a card to creat a lip for leverage.
  4. Boombotix Boombot Mini Speaker Replacement: paso 4, imagen 1 de 1
    • Find the connection of the speaker by following the wires.
    • Do not damage the battery. Make sure not to use any metal object to poke around in the device because of possible shock.
  5. Boombotix Boombot Mini Speaker Replacement: paso 5, imagen 1 de 2 Boombotix Boombot Mini Speaker Replacement: paso 5, imagen 2 de 2
    • Now that you have found the wire connection to the motherboard, disconnect it.
    • Pull the wire straight out.
  6. Boombotix Boombot Mini Speaker Replacement: paso 6, imagen 1 de 1
    • Connect the white plug of the new speaker to the motherboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,421
