Qué necesitas
On the back of the device, remove the four 3/8" Torx head screws using the T-6 Torx bit.
Use a pair of tweezers or a small, pointed object to gently pull the connector out on both the left and right sides.
Using a spudger or prying tool, lift the connected screen and motherboard straight up to expose the gold-colored antenna taped to the back plate.
Using a spudger or your fingernail, remove the black electrical tape securing the antenna to the black plate.
On the back side of the antenna, use a spudger or your fingernail to remove the transparent tape holding the transformer to the antenna.
Gently pull apart the transformer from the back of the anenna.
Una persona más ha completado esta guía.
