Herramientas Destacadas en este Teardown
Este desmontaje no es una guía de reparación. Para reparar tu Bluetooth earphone, utiliza nuestros manuales de servicio .
  1. with some thin pliers or a blade pry open the button case the 2 pieces should come off with easy with some thin pliers or a blade pry open the button case the 2 pieces should come off with easy with some thin pliers or a blade pry open the button case the 2 pieces should come off with easy
    • with some thin pliers or a blade pry open the button case the 2 pieces should come off with easy
  2. using some thin tool separate the earphone case to expose the speaker just separate it a little wait for the next step
    • using some thin tool separate the earphone case
    • to expose the speaker just separate it a little wait for the next step
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. with the sharp pliers cut away the plastic around the speaker just half way push back the black part to have more room to work
    • with the sharp pliers cut away the plastic around the speaker just half way
    • push back the black part to have more room to work
  5. take off they cover after cutting it with a blade take off the white foam
    • take off they cover after cutting it
    • with a blade take off the white foam
    • after this step the whole earphones should be exposed
Jose A. Loza
Miembro Desde 13/04/18
331 Reputación
2 Guías creadas
Hi Jose, did you happen to see the Bluetooth chip used in this product ?
Rajesh Gunasekaran - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 17
Últimos 30 Días: 52
Todo El Tiempo: 791
