Introducción
If your phone is not responding when you are pressing the power button, you may need a power button replacement. This guide has been made to help you install your power button on your own. It will show you how to remove the screws, removing the back panel, and detach the power button.
  1. Before beginning this guide, make sure this is the guide you have selected.
    • Before beginning this guide, make sure this is the guide you have selected.
    • After assuring the guide, locate the power button show in Figure 1.
  2. Begin by locating the torx screws and remove them show in (Figure 1).
    • Begin by locating the torx screws and remove them show in (Figure 1).
    • After removing the screws, begin by use the suction tool and pry tool, to slowly remove the black plate.
    • Be Cautious do not damage phone display and or inside components while using pry tool and suction tool.
    • Once the back panel is removed, locate the power button, remove it, and replace it with the new power button show in figure 1.
    • After you successfully replace the power button, repeat the steps in reverse order to reassemble the phone.
Conclusión
Alan Rodriguez
Miembro Desde 10/09/18
279 Reputación
2 Guías creadas
Equipo
Gateway, Team S1-G3, Luster Fall 2018 Miembro de Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Miembros
4 Guías creadas
Don’t forget to remove the SIM card
Jonathan - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 28
Todo El Tiempo: 39
