Saltar al contenido principal
Blu Studio Selfie Rear Cover Replacement
Qué necesitas
  1. Blu Studio Selfie Rear Cover Replacement, Rear Cover: paso 1, imagen 1 de 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Rear Cover Replacement: paso 2, imagen 1 de 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
Conclusión
2 personas más completaron esta guía.
Stacy Kam
Miembro Desde 01/20/16
630 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 10-1, Remmell Spring 2016 Miembro de USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 269
