Saltar al contenido principal
Introducción
In this guide you'll be opening the back panel of your Blu Studio, this is the first step you'll take whenever you replace or add internal parts.
If you don't have any fingernails you may want to use the plastic prying tools.
Partes
No se especificaron partes.
  1. Blu Studio HD 6.0 Rear Case Replacement, Rear Case: paso 1, imagen 1 de 1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Rear Case Replacement, Back Panel.: paso 2, imagen 1 de 2 Blu Studio HD 6.0 Rear Case Replacement, Back Panel.: paso 2, imagen 2 de 2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Rear Case Replacement: paso 3, imagen 1 de 2 Blu Studio HD 6.0 Rear Case Replacement: paso 3, imagen 2 de 2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
Conclusión
7 personas más completaron esta guía.
Erik reinbolt
Miembro Desde 23/09/14
1,548 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 9-1, Blackwell Fall 2014 Miembro de USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,123
