Saltar al contenido principal
Introducción
Installing a Micro-SD card is a quick and easy way to expand your device's storage. Follow this guide to install your Micro-SD card correctly.
Herramientas
No se especificaron herramientas.
Partes
  1. Begin by making sure your Blu Studio is turned off.
    • Begin by making sure your Blu Studio is turned off.
  2. To begin the removal of your back panel, first locate the lift tab on the bottom-right corner. To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed. Your rear panel should be placed nearby and in a safe location until you are finished with your task.
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Find the Micro-SD card slot which is under the right SIM card slot. Line up the gold pins of the Micro-SD card with the pins of the card slot. If pins in the slot are hidden, then insert the Micro-SD card with the "MicroSD" print up and the pins facing the slot. Slide the card into the slot until you either hear a clicking noise or until the card does not move anymore. Do not apply too much force; gently slide it in and stop immediately when it does not move anymore.
    • Find the Micro-SD card slot which is under the right SIM card slot.
    • Line up the gold pins of the Micro-SD card with the pins of the card slot. If pins in the slot are hidden, then insert the Micro-SD card with the "MicroSD" print up and the pins facing the slot.
    • Slide the card into the slot until you either hear a clicking noise or until the card does not move anymore. Do not apply too much force; gently slide it in and stop immediately when it does not move anymore.
  5. Your phone should boot up and ask you to format your Micro-SD Card.
    • Your phone should boot up and ask you to format your Micro-SD Card.
    • Format the card and you're good to go.
    • If your phone does not recognize the card, ensure that the gold pins of the card aligned with the gold pins on the phone's Micro-SD slot.
    • If the card is installed correctly, the card may be faulty. If so contact the Micro-SD card manufacturer.
Conclusión
8 personas más completaron esta guía.
Alec
Miembro Desde 23/09/14
617 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 9-1, Blackwell Fall 2014 Miembro de USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Miembros
8 Guías creadas
Un Comentario
Very clear instructions and step by step guidance
Laszlo Tihanyi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 16,001
