Saltar al contenido principal
Blu Studio 5.5 S Speaker Replacement
Qué necesitas
  1. Blu Studio 5.5 S Speaker Replacement, Back Casing: paso 1, imagen 1 de 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Speaker Replacement, Applying Pressure: paso 2, imagen 1 de 3 Blu Studio 5.5 S Speaker Replacement, Applying Pressure: paso 2, imagen 2 de 3 Blu Studio 5.5 S Speaker Replacement, Applying Pressure: paso 2, imagen 3 de 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Speaker Replacement, Battery: paso 3, imagen 1 de 3 Blu Studio 5.5 S Speaker Replacement, Battery: paso 3, imagen 2 de 3 Blu Studio 5.5 S Speaker Replacement, Battery: paso 3, imagen 3 de 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Speaker Replacement, Midframe: paso 4, imagen 1 de 3 Blu Studio 5.5 S Speaker Replacement, Midframe: paso 4, imagen 2 de 3 Blu Studio 5.5 S Speaker Replacement, Midframe: paso 4, imagen 3 de 3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Speaker Replacement, Aesthetic Bottom Case: paso 5, imagen 1 de 1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Speaker Replacement: paso 6, imagen 1 de 3 Blu Studio 5.5 S Speaker Replacement: paso 6, imagen 2 de 3 Blu Studio 5.5 S Speaker Replacement: paso 6, imagen 3 de 3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Speaker Replacement, Speaker: paso 7, imagen 1 de 3 Blu Studio 5.5 S Speaker Replacement, Speaker: paso 7, imagen 2 de 3 Blu Studio 5.5 S Speaker Replacement, Speaker: paso 7, imagen 3 de 3
    • The speaker is located on the bottom of the back inner case. To remove it, use a pair of angled tweezers.
    • Use the tweezers to remove the speaker off of the casing.
    • Only put the tweezers in enough to gain leverage.
Conclusión
Una persona más ha completado esta guía.
Cody Dyl
Miembro Desde 10/27/14
804 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 4-8, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 5
Todo El Tiempo: 1,166
