Saltar al contenido principal
Blu Studio 5.5 S Rear Facing Camera Replacement
Qué necesitas
  1. Blu Studio 5.5 S Rear Facing Camera Replacement, Back Casing: paso 1, imagen 1 de 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Rear Facing Camera Replacement, Applying Pressure: paso 2, imagen 1 de 3 Blu Studio 5.5 S Rear Facing Camera Replacement, Applying Pressure: paso 2, imagen 2 de 3 Blu Studio 5.5 S Rear Facing Camera Replacement, Applying Pressure: paso 2, imagen 3 de 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Rear Facing Camera Replacement, Battery: paso 3, imagen 1 de 3 Blu Studio 5.5 S Rear Facing Camera Replacement, Battery: paso 3, imagen 2 de 3 Blu Studio 5.5 S Rear Facing Camera Replacement, Battery: paso 3, imagen 3 de 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Rear Facing Camera Replacement, Midframe: paso 4, imagen 1 de 3 Blu Studio 5.5 S Rear Facing Camera Replacement, Midframe: paso 4, imagen 2 de 3 Blu Studio 5.5 S Rear Facing Camera Replacement, Midframe: paso 4, imagen 3 de 3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Rear Facing Camera Replacement, Aesthetic Bottom Case: paso 5, imagen 1 de 1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Rear Facing Camera Replacement: paso 6, imagen 1 de 3 Blu Studio 5.5 S Rear Facing Camera Replacement: paso 6, imagen 2 de 3 Blu Studio 5.5 S Rear Facing Camera Replacement: paso 6, imagen 3 de 3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Rear Facing Camera Replacement, Back Camera.: paso 7, imagen 1 de 3 Blu Studio 5.5 S Rear Facing Camera Replacement, Back Camera.: paso 7, imagen 2 de 3 Blu Studio 5.5 S Rear Facing Camera Replacement, Back Camera.: paso 7, imagen 3 de 3
    • The rear camera is located in the center of the motherboard . It is connected by a ribbon wire / prong system.
    • Use tweezers to gently pop off the prong system, by pulling upwards on the black cap piece connected to the motherboard from the ribbon wire.
    • Use the Tweezers to pull the camera out of the housing.
    • When removing the back camera be careful not to scratch the lens, unless you are throwing it out.
Conclusión
Una persona más ha completado esta guía.
Cody Dyl
Miembro Desde 10/27/14
804 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 4-8, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 1,483
