Saltar al contenido principal
Blu Studio 5.5 S Battery Replacement
  1. Blu Studio 5.5 S Battery Replacement, Back Casing: paso 1, imagen 1 de 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Battery Replacement, Applying Pressure: paso 2, imagen 1 de 3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: paso 2, imagen 2 de 3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: paso 2, imagen 3 de 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Battery Replacement, Battery: paso 3, imagen 1 de 3 Blu Studio 5.5 S Battery Replacement, Battery: paso 3, imagen 2 de 3 Blu Studio 5.5 S Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
Conclusión
7 personas más completaron esta guía.
Cody Dyl
Miembro Desde 10/27/14
804 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 4-8, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 6,145
