Saltar al contenido principal
Blu Studio 5.5 S Back Case Replacement
  1. Blu Studio 5.5 S Back Case Replacement, Back Casing: paso 1, imagen 1 de 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Back Case Replacement, Applying Pressure: paso 2, imagen 1 de 3 Blu Studio 5.5 S Back Case Replacement, Applying Pressure: paso 2, imagen 2 de 3 Blu Studio 5.5 S Back Case Replacement, Applying Pressure: paso 2, imagen 3 de 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
Conclusión
To reassemble your device, insert the two tabs located at the bottom of the cover into the indents at the bottom of the phone. Then, press down on all sides of the phone until you hear it snap into place.
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team 4-8, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 17
Todo El Tiempo: 1,024
