Saltar al contenido principal
Blu Studio 5.5 Camera Replacement
Qué necesitas
  1. Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
    Blu Studio 5.5 Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Flip over your Studio 5.5 so the back is facing you.
    • Use either the spudger or your fingernail to pull up on the slot in the lower left corner and remove the back cover.
  2. Blu Studio 5.5 Camera Replacement: paso 2, imagen 1 de 2 Blu Studio 5.5 Camera Replacement: paso 2, imagen 2 de 2
    • Place your finger in the small groove beneath the battery.
    • Push the battery toward the top of the phone and lift it out.
  3. Blu Studio 5.5 Camera Replacement, Camera: paso 3, imagen 1 de 1
    • Begin by removing the 12 3.5mm screws along the back of the device.
    • 1 of these screws will be underneath a white sticker. Just press the screwdriver through it and remove it normally.
  4. Blu Studio 5.5 Camera Replacement: paso 4, imagen 1 de 2 Blu Studio 5.5 Camera Replacement: paso 4, imagen 2 de 2
    • Using your plastic opening tool, begin carefully prying the plastic shell from the phone.
    • Make your way around the edge slowly and lift the shell off when you have made a full circuit.
  5. Blu Studio 5.5 Camera Replacement: paso 5, imagen 1 de 1
    • Locate and unplug seven connectors on the motherboard.
    • Those marked in red are pulled straight up, away from the phone.
    • The connector marked in orange is pulled out horizontally.
  6. Blu Studio 5.5 Camera Replacement: paso 6, imagen 1 de 1
    • Unscrew the three 3.5mm screws securing the motherboard in place.
  7. Blu Studio 5.5 Camera Replacement: paso 7, imagen 1 de 1
    • Using the plastic opening tool, you can now lift the motherboard straight up and out.
  8. Blu Studio 5.5 Camera Replacement: paso 8, imagen 1 de 1
    • Carefully wedge the plastic remover tool underneath the corner of the camera module and slowly pry until it comes free.
  9. Blu Studio 5.5 Camera Replacement: paso 9, imagen 1 de 3 Blu Studio 5.5 Camera Replacement: paso 9, imagen 2 de 3 Blu Studio 5.5 Camera Replacement: paso 9, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to lift the camera module out, taking care not to get any fingerprints on it.
    • During reassembly, make sure the ribbon attached to the camera goes up and through the square hole on the motherboard so it is able to reconnect properly.
Conclusión
3 personas más completaron esta guía.
Brian Sullivan
Miembro Desde 10/22/14
647 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-2, Shastany Fall 2014 Miembro de UMass Dartmouth, Team 1-2, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G2
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,092
