Qué necesitas
Remove the cover by lifting the notch towards the bottom of the phone. Use your fingernail to lift it up.
Remove these nine screws with a small phillips screwdriver. They are all the same size.
There is a small screw hidden under the warranty sticker. You may either remove or poke through it .
Use the pry tool to gently separate the panel from the frame, starting from the bottom left corner and continue along the edge of the phone.
*WARNING* by doing this, you will void the manufacturers warranty.
Continue using the pry tool around the back panel of the phone to separate both pieces.
Once you have gone around the entire frame, use both hands to pull it apart.
