Saltar al contenido principal
Blu L120 MicroSD Card Replacement
Qué necesitas
  1. Blu L120 MicroSD Card Replacement, Adding additional storage: paso 1, imagen 1 de 2 Blu L120 MicroSD Card Replacement, Adding additional storage: paso 1, imagen 2 de 2
    • Turn off the device, and remove the back cover. Start on the notch above the charging port and lift cover up and gently work around the phone until the back cover is off.
    • Remove the battery.
  2. Blu L120 MicroSD Card Replacement, Adding additional storage: paso 2, imagen 1 de 2 Blu L120 MicroSD Card Replacement, Adding additional storage: paso 2, imagen 2 de 2
    • Insert the media card into the phone. Maximum 32gb micro SD.
    • Reinstall the battery and back cover, and power on your device. Success............. you just added more storage to your phone.
Conclusión
Julio
Miembro Desde 10/25/14
695 Reputación
6 Guías creadas
Equipo
Gateway, Team 1-5, Johnson Fall 2014 Miembro de Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 201
