Saltar al contenido principal
Blu Grand M2 Charging Port Assembly Replacement
Qué necesitas
  1. Blu Grand M2 Charging Port Assembly Replacement, Charging Port Assembly: paso 1, imagen 1 de 1
    • Remove the screws with the T2 Torx screwdriver.
    • Place screws off to the side.
  2. Blu Grand M2 Charging Port Assembly Replacement: paso 2, imagen 1 de 2 Blu Grand M2 Charging Port Assembly Replacement: paso 2, imagen 2 de 2
    • Once the Torx screws have been removed, use a pry tool and a suction tool to remove the back plate.
    • Using the T2 Torx screwdriver, remove the six Torx screws on the motherboard.
    • Make sure to disconnect all other connections from the camera.
  3. Blu Grand M2 Charging Port Assembly Replacement: paso 3, imagen 1 de 1
    • Carefully pry the motherboard assembly from the phone.
    • The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
    • Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
    • After installing the new port, repeat the steps in reverse order to reassemble the phone.
    • How to Solder and Desolder Connections
Conclusión
Una persona más ha completado esta guía.
Richard Hills
Miembro Desde 09/10/18
150 Reputación
1 Guía escrita
Equipo
Gateway, Team S1-G3, Luster Fall 2018 Miembro de Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 496
