Saltar al contenido principal
Blu Grand M2 Power Button Replacement
Qué necesitas
  1. Blu Grand M2  Power Button Replacement, Power Button: paso 1, imagen 1 de 1
    • Using a T2 Torx Screwdriver, remove the two screws from the bottom edge of the phone.
  2. Blu Grand M2  Power Button Replacement: paso 2, imagen 1 de 2 Blu Grand M2  Power Button Replacement: paso 2, imagen 2 de 2
    • Apply the suction tool to the back panel near the bottom edge.
    • Carefully slide the device pick between the back panel and bottom edge.
    • Insert the opening tool into the gap created by the device pick.
    • While holding the suction tool, use the opening tool to gently pry the back panel off.
    • Be Cautious to not damage the phone display and or the inside components while using the pry tool and suction tool.
  3. Blu Grand M2  Power Button Replacement: paso 3, imagen 1 de 1
    • Take the end of the opening tool and push the old power button out of its socket.
    • Remove the old power button.
  4. Blu Grand M2  Power Button Replacement: paso 4, imagen 1 de 1
    • Place the new BLU Grand M2 power button in the socket.
Conclusión
Alan Rodriguez
Miembro Desde 09/10/18
311 Reputación
2 Guías creadas
Equipo
Gateway, Team S1-G3, Luster Fall 2018 Miembro de Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Miembros
4 Guías creadas
Un comentario
Don’t forget to remove the SIM card
Jonathan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 353
