Saltar al contenido principal
Blu Grand M Motherboard Replacement
Qué necesitas
  1. Blu Grand M Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Blu Grand M Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Motherboard Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Motherboard Replacement: paso 3, imagen 1 de 3 Blu Grand M Motherboard Replacement: paso 3, imagen 2 de 3 Blu Grand M Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Motherboard Replacement: paso 4, imagen 1 de 2 Blu Grand M Motherboard Replacement: paso 4, imagen 2 de 2
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Motherboard Replacement, Plastic Plate: paso 5, imagen 1 de 2 Blu Grand M Motherboard Replacement, Plastic Plate: paso 5, imagen 2 de 2
    • Remove the yellow plastic tape using a pair of tweezers.
  6. Blu Grand M Motherboard Replacement: paso 6, imagen 1 de 3 Blu Grand M Motherboard Replacement: paso 6, imagen 2 de 3 Blu Grand M Motherboard Replacement: paso 6, imagen 3 de 3
    • Use a Phillips #000 screwdriver to remove two black 4.0mm screws.
    • Use a Phillips #000 screwdriver to remove 2 silver 4.0mm screws
    • Remove the plastic cover along the top by tugging on it on the corner as shown.
  7. Blu Grand M Motherboard Replacement, Motherboard: paso 7, imagen 1 de 2 Blu Grand M Motherboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Place a spudger or other tool underneath the black wire.
    • Lift up on the gold coaxial cable connector so it disconnects from the motherboard.
  8. Blu Grand M Motherboard Replacement: paso 8, imagen 1 de 3 Blu Grand M Motherboard Replacement: paso 8, imagen 2 de 3 Blu Grand M Motherboard Replacement: paso 8, imagen 3 de 3
    • Using the the narrow tip of a nylon spudger, open the two cable connector ports.
  9. Blu Grand M Motherboard Replacement: paso 9, imagen 1 de 2 Blu Grand M Motherboard Replacement: paso 9, imagen 2 de 2
    • Insert the spudger underneath the ribbon cable.
    • Pull the ribbon cable away from the gray connector.
    • The cable should pull away free from the gray connector without any resistance.
    • If you encounter resistance, check to see that the black cable connector port is open.
  10. Blu Grand M Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the four 4.0mm screws with a Philips #000 screwdriver.
  11. Blu Grand M Motherboard Replacement: paso 11, imagen 1 de 2 Blu Grand M Motherboard Replacement: paso 11, imagen 2 de 2
    • Lift the motherboard up and slightly away from the smartphone frame using the nylon tipped tweezers or other ESD safe tool.
    • The motherboard is still connected to the frame via a large black ribbon cable. Do not lift higher than this ribbon allows.
    • Flip the motherboard upside down to reveal the ribbon cable connector.
  12. Blu Grand M Motherboard Replacement: paso 12, imagen 1 de 2 Blu Grand M Motherboard Replacement: paso 12, imagen 2 de 2
    • A large black ribbon cable is connected to the underside of the motherboard.
    • Use the spudger to open the orange plastic ribbon connector.
  13. Blu Grand M Motherboard Replacement: paso 13, imagen 1 de 2 Blu Grand M Motherboard Replacement: paso 13, imagen 2 de 2
    • Insert the spudger into the folded ribbon cable loop.
    • Pull the ribbon cable away from the black plastic connector.
    • The ribbon cable should pull away from the black connector without any resistance.
  14. Blu Grand M Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the motherboard with the nylon tweezers.
    • Place the motherboard on an electrostatic discharge (ESD) safe material.
Conclusión
To reassemble your, follow these instructions in reverse order.
Note: The ribbon clamp connector, also known as a Zero Insertion Force (ZIF) connector, might be difficult to reinsert. Follow the reinstallation step at the end of this guide: Reconocimiento y desconexión de conectores de cable.
Liam Rollins
Miembro Desde 11/04/19
253 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 203
