Saltar al contenido principal
Blu Grand M Microphone Replacement
Qué necesitas
  1. Blu Grand M Microphone Replacement, Battery: paso 1, imagen 1 de 2 Blu Grand M Microphone Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Microphone Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Microphone Replacement: paso 3, imagen 1 de 3 Blu Grand M Microphone Replacement: paso 3, imagen 2 de 3 Blu Grand M Microphone Replacement: paso 3, imagen 3 de 3
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Microphone Replacement: paso 4, imagen 1 de 2 Blu Grand M Microphone Replacement: paso 4, imagen 2 de 2
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Microphone Replacement, Speaker: paso 5, imagen 1 de 2 Blu Grand M Microphone Replacement, Speaker: paso 5, imagen 2 de 2
    • Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
    • Remove the 4.0mm screw with a Phillips #000 screwdriver.
    • Using the blue plastic opening tool, remove the exterior cover.
  6. Blu Grand M Microphone Replacement: paso 6, imagen 1 de 3 Blu Grand M Microphone Replacement: paso 6, imagen 2 de 3 Blu Grand M Microphone Replacement: paso 6, imagen 3 de 3
    • Use a Phillips #000 screwdriver to remove each of the four 1.5mm screws.
    • Use a Phillips #000 screwdriver to remove each of the three 3.0mm screws.
    • Use the plastic opening tool to remove the speaker.
  7. Blu Grand M Microphone Replacement, Microphone: paso 7, imagen 1 de 2 Blu Grand M Microphone Replacement, Microphone: paso 7, imagen 2 de 2
    • Disconnect the black wire with a pair of tweezers.
    • The black wire can swivel out of the way to easily access the next microphone.
  8. Blu Grand M Microphone Replacement: paso 8, imagen 1 de 2 Blu Grand M Microphone Replacement: paso 8, imagen 2 de 2
    • Use a pair of tweezers to remove the orange data cable as shown.
  9. Blu Grand M Microphone Replacement: paso 9, imagen 1 de 3 Blu Grand M Microphone Replacement: paso 9, imagen 2 de 3 Blu Grand M Microphone Replacement: paso 9, imagen 3 de 3
    • There will be glue holding the wires down, and they can be glued back in place after.
    • Use the plastic opening tool to lift the microphone out of place.
    • Use a pair of tweezers to lift the microphone out of the phone.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 149
