Saltar al contenido principal
Blu Grand M Display Replacement
Qué necesitas
  1. Blu Grand M Display Replacement, Display: paso 1, imagen 1 de 1
    • Trace the outer black edge of the phone screen in a continuous circle with a hairdryer or heat gun to melt the adhesive.
    • Melting the adhesive can take between 2-3 minutes.
  2. Blu Grand M Display Replacement: paso 2, imagen 1 de 3 Blu Grand M Display Replacement: paso 2, imagen 2 de 3 Blu Grand M Display Replacement: paso 2, imagen 3 de 3
    • Insert an opening pick between the screen and the raised black plastic frame.
    • The black plastic frame is located inside and above the phone's silvery outer metal frame.
    • Insert the flat blade of a nylon halberd spudger between the screen and the black plastic frame.
    • Pull the spudger blade through the adhesive around the circumference of the screen.
  3. Blu Grand M Display Replacement: paso 3, imagen 1 de 3 Blu Grand M Display Replacement: paso 3, imagen 2 de 3 Blu Grand M Display Replacement: paso 3, imagen 3 de 3
    • Apply the suction cup to the phone screen, pressing lightly on the suction cup to remove air and form a tight seal.
    • The adhesive may have cooled from the time since step 1 and rebonded to the phone screen. Reheat the adhesive if necessary to return to a liquid state.
    • Pull on the handle to lift the screen free from the device.
Linea de Meta
Liam Rollins
Miembro Desde 11/04/19
253 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 245
