Saltar al contenido principal
Blu Dash 5.0 Dual SIM Speaker Replacement
Qué necesitas
  1. Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: paso 1, imagen 1 de 2 Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • Make sure device is disconnected and turned off.
    • Locate the groove at the bottom left corner of the phone.
    • Insert the plastic opening tool in the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Speaker Replacement: paso 2, imagen 1 de 1
    • Pry the battery out from the back of the phone using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the 12 screws located at the back panel of the phone using a J000 screwdriver.
    • The red circles are screw holes that hold the 3.5mm length Phillips screw.
    • The orange circles are screw holes that hold the 2.5mm length Phillips screw.
  4. Blu Dash 5.0 Dual SIM Speaker Replacement: paso 4, imagen 1 de 3 Blu Dash 5.0 Dual SIM Speaker Replacement: paso 4, imagen 2 de 3 Blu Dash 5.0 Dual SIM Speaker Replacement: paso 4, imagen 3 de 3
    • Remove the back panel of the phone with your hand.
    • Carefully remove the plastic back panel to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the antenna cable connectors using a spudger.
  6. Blu Dash 5.0 Dual SIM Speaker Replacement: paso 6, imagen 1 de 1
    • Unscrew the 2.5mm screws from the circuit board holding the speaker at the bottom of the phone.
  7. Blu Dash 5.0 Dual SIM Speaker Replacement: paso 7, imagen 1 de 2 Blu Dash 5.0 Dual SIM Speaker Replacement: paso 7, imagen 2 de 2
    • Flip the ZIF flap up with tweezers.
    • Remove the ribbon cable with tweezers.
    • The ribbon cable is sensitive and needs to be removed carefully to insure its integrity.
  8. Blu Dash 5.0 Dual SIM Speaker Replacement: paso 8, imagen 1 de 2 Blu Dash 5.0 Dual SIM Speaker Replacement: paso 8, imagen 2 de 2
    • Remove the speaker panel with the plastic opening tool.
    • The panel is glued onto the device and will require extra force to remove.
Conclusión
Mukish Kumar Munyady
Miembro Desde 01/30/17
201 Reputación
2 Guías creadas
Equipo
IUPUI, Team 1-1, Baechle Spring 2017 Miembro de IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 266
