Saltar al contenido principal
Blu Dash 5.0 Dual SIM Battery Replacement
Qué necesitas
  1. Blu Dash 5.0 Dual SIM Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
  2. Blu Dash 5.0 Dual SIM Battery Replacement: paso 2, imagen 1 de 1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
Conclusión
5 personas más completaron esta guía.
Dashaya Toney
Miembro Desde 10/27/14
876 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 4-7, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-7, Miles Fall 2014
UMASSD-MILES-F14S4G7
3 Miembros
3 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 4,053
