Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement
Qué necesitas
  1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: paso 1, imagen 1 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: paso 1, imagen 2 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: paso 1, imagen 3 de 3
    • Make sure the diffuser is not plugged into a socket and that there is no water or oil near or in the diffuser before beginning the guide.
    • Use a Phillips #2 screwdriver to remove the four 8 mm screws on the bottom of the diffuser.
    Pregunta a FixBot
    Agregar Comentario
  2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 2, imagen 1 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 2, imagen 2 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 2, imagen 3 de 3
    • Lift the ceramic top of the oil diffuser.
    • Then lift off the plastic top off the diffuser.
    Pregunta a FixBot
    Agregar Comentario
  3. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 3, imagen 1 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 3, imagen 2 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 3, imagen 3 de 3
    • Lift the last plastic lid.
    • You will see a circuit board, and there will be a cord connecting it to the circuit board.
    Pregunta a FixBot
    Agregar Comentario
  4. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 4, imagen 1 de 2 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 4, imagen 2 de 2
    • Gently unplug the cord from the circuit board.
    • Place the plastic lid somewhere safe on the a flat surface.
    Pregunta a FixBot
    Agregar Comentario
  5. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 5, imagen 1 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 5, imagen 2 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 5, imagen 3 de 3
    • Remove the plastic ring and place somewhere safe on a flat surface.
    Pregunta a FixBot
    Agregar Comentario
  6. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 6, imagen 1 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 6, imagen 2 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 6, imagen 3 de 3
    • Remove two Truss head 4 mm screws with a Phillips #2 screwdriver and place safely nearby.
    Pregunta a FixBot
    Agregar Comentario
  7. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 7, imagen 1 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 7, imagen 2 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 7, imagen 3 de 3
    • Gently lift the circuit board onto it's side
    • The white connector plugs the fan into the circuit board.
    Pregunta a FixBot
    Agregar Comentario
  8. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 8, imagen 1 de 2 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 8, imagen 2 de 2
    • Unplug the white connector.
    • There are four #M1 6 mm Phillips pan head screws holding down the fan.
    Pregunta a FixBot
    Agregar Comentario
  9. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 9, imagen 1 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 9, imagen 2 de 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: paso 9, imagen 3 de 3
    • Remove the #M1 6 mm screws with a Phillips #2 screwdriver while holding down the fan.
    • Gently lift the fan and place the fan someplace safe on the flat surface.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Muniira Mohamoud
Miembro Desde 01/18/22
169 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 89
Todo El Tiempo: 1,422
