Introducción
After several years of use, does your Blackvue dashcam show the incorrect date and time for recordings? If so it’s possible that the Real Time Clock (RTC) battery in the dashcam has died. This guide shows how to replace the battery for only a few dollars and less than an hour of work. Disassembly of other models of Blackvue dashcams appears to be very similar, so if you have a different model than the 650GW-2CH, these instructions may still help you.
The replacement battery is a Seiko MS621FE FL11E 3V 5.5mAHr Rechargeable Battery. I purchased mine on Amazon, only C$7.70 for 2.
Herramientas
Partes
Using a small jeweller's flat bladed screwdriver, carefully pry up one corner of the plastic window covering the WiFi LED on the end of the dashcam
Once you've pried the window slightly, you can use a plastic spudger to gently lift up the window without damaging it
Remove the window and set it aside. If you're careful the adhesive will be sticky enough to replace the window securely when you're done with this repair
Near the opposite end of the dashcam from where you removed the plastic window, you'll see a small opening on the side of the end-cap.
Using a small flat bladed screwdriver, press on the plastic tab that you find inside that opening
Pressing on that tab should release the plastic end-cap so that you can slide it off the end of the dashca's cylindrical body
The 3rd photo shows the end-cap after it's been removed
Next step is to separate the two halves of the cylindrical dashcam body. I used an old credit card as well as a spudger tool for this step
Starting from the right end, work your way carefully along the horizontal crack between the two halves using a spudger and/or credit card. Be patient, don't use too much force or you may break one or more of the internal plastic tabs
Once you've loosened the tabs holding one side of the body, turn the dashcam over and loosen the other side.
In the 3rd photo, you can see the location of 2 of the internal tabs holding the body together, in the small opening betwen halves. There are 4 of these internal tabs on each side.
Inside the dashcam, there are two stacked circuit boards. Using a flat bladed screwdriver or spudger tool, gently pry the top circuit board up from the bottom circuit board
There are 3 connectors between the 2 circuit boards holding them together. In the 2nd photo, for reference you can see these 3 connectors (outlined in red), once the boards have been separated. You can also see the bottom side of the upper circuit board here, where the RTC battery is found.
Once you've separated the 2 circuit boards, you'll see the RTC battery mounted on the bottom side of the upper board. In the first photo you'll see it's covered by a piece of clear rubber tubing, for insulation
Carefully slide off the clear rubber tubing/insulation, and set it aside for replacement later.
The 2nd photo shows the RTC battery after the insulation has been removed
Using a soldering iron and desoldering pump, carefully heat the 2 battery terminals and suck off the solder.
A pair of tweezers may be helpful to lift and remove the battery once the solder has been heated
Remove the old battery and clean off any excess solder from the circuit board battery terminals
Position the new battery over the circuit board so its terminals line up with the corresponding pads on the circuit board
Solder the new battery to the circuit board, being careful not to overheat the circuit board traces nor create any shorts.
Slide the rubber tubing/insulation onto the new battery
Carefully align and reconnect the 3 connectors between the two stacked circuit boards together, then reassemble the dashcam body and you're done!
