Saltar al contenido principal
Blackstone Cascade Pro Fan Replacement
Qué necesitas
  1. Blackstone Cascade Pro Fan Replacement, Fan: paso 1, imagen 1 de 3 Blackstone Cascade Pro Fan Replacement, Fan: paso 1, imagen 2 de 3 Blackstone Cascade Pro Fan Replacement, Fan: paso 1, imagen 3 de 3
    • Remove the four screws surrounding the back of the Blackstone fan using a Phillips #00 screwdriver.
    • Remove the cover at the back of the fan.
  2. Blackstone Cascade Pro Fan Replacement: paso 2, imagen 1 de 2 Blackstone Cascade Pro Fan Replacement: paso 2, imagen 2 de 2
    • Remove the diamond cover at the top of the fan.
    • The diamond cover will be connected to a set of wires to the fan. Simply place the cover to the side for the rest of the repair.
  3. Blackstone Cascade Pro Fan Replacement: paso 3, imagen 1 de 3 Blackstone Cascade Pro Fan Replacement: paso 3, imagen 2 de 3 Blackstone Cascade Pro Fan Replacement: paso 3, imagen 3 de 3
    • Remove the two screws that are holding the spherical cover shielding the main fan using a Phillips #00 screwdriver.
    • Remove the spherical cover surrounding the main fan.
  4. Blackstone Cascade Pro Fan Replacement: paso 4, imagen 1 de 2 Blackstone Cascade Pro Fan Replacement: paso 4, imagen 2 de 2
    • On the opposite side there will be a cover identical to the one removed in the previous step.
    • Twist the main fan to remove the cover on the opposite side.
  5. Blackstone Cascade Pro Fan Replacement: paso 5, imagen 1 de 3 Blackstone Cascade Pro Fan Replacement: paso 5, imagen 2 de 3 Blackstone Cascade Pro Fan Replacement: paso 5, imagen 3 de 3
    • Using the socket wrench, and a size 10 shallow socket, remove the hexagon screw at the center of the main fan.
    • Pull out the main fan.
    • Depending on the age of your fan, it may require more strength to pull it out. Be careful to not use too much force.
Conclusión
2 personas más completaron esta guía.
Mohamed Mallah
Miembro Desde 01/24/24
148 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 294
