Saltar al contenido principal
Blackberry Z20 Leap LCD/Digitizer Replacement Replacement
Qué necesitas
  1. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, Blackberry Leap Screen Replacement: paso 1, imagen 1 de 2 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, Blackberry Leap Screen Replacement: paso 1, imagen 2 de 2
    • Blackberry Z20 Leap (STR200-2) with a bad LCD. The first question is...Where are the screws?
  2. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, remove screws: paso 2, imagen 1 de 2 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, remove screws: paso 2, imagen 2 de 2
    • The screws are behind the sticker beside the camera. Heat the sticker and use a knife to pry under the sticker to remove it. There are 2 screws which you need a T6 torx screwdriver to remove.
  3. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, unseat screen assembly: paso 3, imagen 1 de 3 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, unseat screen assembly: paso 3, imagen 2 de 3 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, unseat screen assembly: paso 3, imagen 3 de 3
    • Push up on screen with thumbs once the screws have been removed. The screen assembly will now come away from the chassis. Be careful there is still some ribbon cables connected to the screen assembly.
  4. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, disconnect connectors: paso 4, imagen 1 de 3 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, disconnect connectors: paso 4, imagen 2 de 3 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, disconnect connectors: paso 4, imagen 3 de 3
    • In the top there is a connector where you have to lift the black part of the connector to remove the ribbon. I used tweezers to lift the connector and to remove the ribbon cable
    • Once the top ribbon is removed there is another cable connected in the middle. The phone will open up more to give you access. You will need to lift the black part of the connector to remove the ribbon. Again, I used tweezers. The screen assembly should now come away from the chassis
Conclusión
9 personas más completaron esta guía.
Amanda Baxter
Miembro Desde 02/08/16
217 Reputación
1 Guía escrita
8 comentarios
Excellent Guide Amanda! thanks for the great work!
Xpider - Contestar
How to remove lcd from the frame (bezel)
Sani Shik - Contestar
Can you advise how this is done please...removing the lcd from the frame
zoe smith -
I bought a T6 torx screwdriver but it is too big for my Leap (STR200-1). Any idea what size torx I need? I'm guessing T5 but...
Dave - Contestar
Yep bought a T5 torx screwdriver and that did it
Dave - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 5,344
