Saltar al contenido principal
Blackberry Torch 9810 Motherboard Replacement
Qué necesitas
  1. Blackberry Torch 9810 Motherboard Replacement, Phone cover: paso 1, imagen 1 de 2 Blackberry Torch 9810 Motherboard Replacement, Phone cover: paso 1, imagen 2 de 2
    • Remove the back cover of the phone
  2. Blackberry Torch 9810 Motherboard Replacement, Battery Removal: paso 2, imagen 1 de 1
    • Remove the battery
  3. Blackberry Torch 9810 Motherboard Replacement, Remove Screws: paso 3, imagen 1 de 1
    • Unscrew the four screws using the T6 screw driver
    • If you remove the screw in red, you void the warranty!
  4. Blackberry Torch 9810 Motherboard Replacement, Wiggle Wiggle: paso 4, imagen 1 de 2 Blackberry Torch 9810 Motherboard Replacement, Wiggle Wiggle: paso 4, imagen 2 de 2
    • Remove front silver trim by using plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
  5. Blackberry Torch 9810 Motherboard Replacement, More Screws: paso 5, imagen 1 de 1
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
  6. Blackberry Torch 9810 Motherboard Replacement, Remove the Back: paso 6, imagen 1 de 3 Blackberry Torch 9810 Motherboard Replacement, Remove the Back: paso 6, imagen 2 de 3 Blackberry Torch 9810 Motherboard Replacement, Remove the Back: paso 6, imagen 3 de 3
    • Use the plastic removal tool to remove the entire back cover.
  7. Blackberry Torch 9810 Motherboard Replacement, Small Antenna Wire: paso 7, imagen 1 de 1
    • Unplug the black antenna wire from the logic board.
  8. Blackberry Torch 9810 Motherboard Replacement, Remove Ribbon Cables: paso 8, imagen 1 de 2 Blackberry Torch 9810 Motherboard Replacement, Remove Ribbon Cables: paso 8, imagen 2 de 2
    • Peel off the three ribbon cables
    • They are orange and located on each side as well as on the top of the logic board
    • The cable circled in yellow is glued to the silver cap. Pull the ribbon cable upward towards the battery area.
  9. Blackberry Torch 9810 Motherboard Replacement, Logic Board: paso 9, imagen 1 de 1
    • Take out your logic board
Conclusión
5 personas más completaron esta guía.
Jocelyn Adorno
Miembro Desde 10/16/14
296 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 3,406
