Saltar al contenido principal
Blackberry Torch 9810 Cursor Key Replacement
Qué necesitas
  1. Blackberry Torch 9810 Cursor Key Replacement, Phone cover: paso 1, imagen 1 de 2 Blackberry Torch 9810 Cursor Key Replacement, Phone cover: paso 1, imagen 2 de 2
    • Remove the back cover of the phone
  2. Blackberry Torch 9810 Cursor Key Replacement, Battery: paso 2, imagen 1 de 1
    • Remove the battery
  3. Blackberry Torch 9810 Cursor Key Replacement, Remove screws: paso 3, imagen 1 de 1
    • Unscrew the four screws using the T6 screw driver.
    • If you remove the screw in red, you void the warranty!
  4. Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: paso 4, imagen 1 de 2 Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: paso 4, imagen 2 de 2
    • Slide the screen up.
    • Remove front silver trim by using a plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
  5. Blackberry Torch 9810 Cursor Key Replacement, More screws that need to go: paso 5, imagen 1 de 1
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
  6. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: paso 6, imagen 1 de 3 Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: paso 6, imagen 2 de 3 Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: paso 6, imagen 3 de 3
    • Use the plastic opening tools to remove the entire back off the phone.
  7. Blackberry Torch 9810 Cursor Key Replacement, Remove Ribbon Cables: paso 7, imagen 1 de 1
    • Remove the three ribbon cables and the antenna wire by hand.
    • The cable in red is glued to the metal cap. Peel it upwards towards the battery compartment.
  8. Blackberry Torch 9810 Cursor Key Replacement, Remove Logic Board: paso 8, imagen 1 de 1
    • The logic board will easily pull straight out.
  9. Blackberry Torch 9810 Cursor Key Replacement, Remove Informational Sticker: paso 9, imagen 1 de 1
    • Remove the black sticker located above the logic board that contains the phone's serial number
  10. Blackberry Torch 9810 Cursor Key Replacement, Remove More Screws: paso 10, imagen 1 de 1
    • Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
  11. Blackberry Torch 9810 Cursor Key Replacement, Separate the phone: paso 11, imagen 1 de 1
    • Carefully separate the screen from the body.
    • Make sure to be extra careful with the ribbon!
  12. Blackberry Torch 9810 Cursor Key Replacement: paso 12, imagen 1 de 1
    • Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
    • They are on a black cover located on the bottom of the phone. The black cover will come off
  13. Blackberry Torch 9810 Cursor Key Replacement, Carefully Remove a Ribbion: paso 13, imagen 1 de 1
    • There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
  14. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: paso 14, imagen 1 de 3 Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: paso 14, imagen 2 de 3 Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: paso 14, imagen 3 de 3
    • Push the cursor upwards and out of the socket.
    • Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
Conclusión
Una persona más ha completado esta guía.
Jocelyn Adorno
Miembro Desde 10/16/14
296 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 1,462
