Saltar al contenido principal
Blackberry Torch 9800 Replacing rear camera
Qué necesitas
  1. Blackberry Torch 9800 Replacing rear camera, Replacing rear camera: paso 1, imagen 1 de 2 Blackberry Torch 9800 Replacing rear camera, Replacing rear camera: paso 1, imagen 2 de 2
    • Remove the back cover and the battery.
    • Remove the four exposed screws using a T7 screwdriver.
    • Warning: Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Replacing rear camera: paso 2, imagen 1 de 2 Blackberry Torch 9800 Replacing rear camera: paso 2, imagen 2 de 2
    • Remove the side trim using the plastic opening tool.
    • When loose, push the top backwards and the bottom forwards to remove.
  3. Blackberry Torch 9800 Replacing rear camera: paso 3, imagen 1 de 3 Blackberry Torch 9800 Replacing rear camera: paso 3, imagen 2 de 3 Blackberry Torch 9800 Replacing rear camera: paso 3, imagen 3 de 3
    • Two new screws have been exposed near the top of the back.
    • Remove the two screws using the T7 screwdriver.
    • Remove the back panel using the plastic opening tool.
  4. Blackberry Torch 9800 Replacing rear camera: paso 4, imagen 1 de 2 Blackberry Torch 9800 Replacing rear camera: paso 4, imagen 2 de 2
    • Carefully use flathead screwdriver to free camera sensor.
    • Wiggle on the right and left sides, not the top and bottom sides.
  5. Blackberry Torch 9800 Replacing rear camera: paso 5, imagen 1 de 1
    • To install the new camera sensor, place in slot. Reassemble phone by doing steps 1-3 in reverse order.
Conclusión
Una persona más ha completado esta guía.
0delete
Miembro Desde 02/16/16
183 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-5, Garvin Spring 2016 Miembro de Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 284
