Saltar al contenido principal
Blackberry Torch 9800 Logic Board Replacement
Qué necesitas
  1. Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: paso 1, imagen 1 de 2 Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: paso 1, imagen 2 de 2
    • Remove the back cover and the battery.
    • Unscrew the four screws using a T6 screwdriver.
    • Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Logic Board Replacement: paso 2, imagen 1 de 2 Blackberry Torch 9800 Logic Board Replacement: paso 2, imagen 2 de 2
    • Remove the side trim using the plastic opening tool.
    • Apply pressure to push the top side of the side trim towards the phone while pulling the bottom away from the phone to remove the side trim.
    • The side trim is fragile and easily fractured, so handful it with care.
  3. Blackberry Torch 9800 Logic Board Replacement: paso 3, imagen 1 de 3 Blackberry Torch 9800 Logic Board Replacement: paso 3, imagen 2 de 3 Blackberry Torch 9800 Logic Board Replacement: paso 3, imagen 3 de 3
    • Remove the two screws that have been revealed at the top of the device using the T6 screwdriver.
    • You should now be able to easily lift the back panel from the phone.
  4. Blackberry Torch 9800 Logic Board Replacement: paso 4, imagen 1 de 2 Blackberry Torch 9800 Logic Board Replacement: paso 4, imagen 2 de 2
    • Using your hands, carefully peel the three ribbon cable caps from the logic board.
  5. Blackberry Torch 9800 Logic Board Replacement: paso 5, imagen 1 de 2 Blackberry Torch 9800 Logic Board Replacement: paso 5, imagen 2 de 2
    • Lift logic board slightly. The logic board will remain attached to the phone by a small antenna wire.
    • Using your hands, carefully lift the clasp attached to the antenna wire straight upward away from the logic board.
    • Make sure not to disconnect the antenna wire from its clasp.
    • The logic board should now be completely separate from the phone.
Conclusión
3 personas más completaron esta guía.
Keegan Williams
Miembro Desde 02/19/16
216 Reputación
2 Guías creadas
Equipo
Ohio State, Team 1-5, Garvin Spring 2016 Miembro de Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 878
