Saltar al contenido principal
Blackberry Storm 9530 Battery Replacement
Qué necesitas
  1. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: paso 1, imagen 1 de 3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: paso 1, imagen 2 de 3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: paso 1, imagen 3 de 3
    • Locate the two switches toward the bottom corners of the device's back cover.
    • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
    • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
  2. Blackberry Storm 9530 Battery Replacement: paso 2, imagen 1 de 1
    • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
    • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
    • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
Conclusión
melanie lim
Miembro Desde 04/22/14
607 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 9-16, Regan Spring 2014 Miembro de Cal Poly, Team 9-16, Regan Spring 2014
CPSU-REGAN-S14S9G16
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,632
