Saltar al contenido principal
Blackberry RIM 7250 Side Button Replacement
Qué necesitas
  1. Blackberry RIM 7250 Side Button Replacement, Battery: paso 1, imagen 1 de 3 Blackberry RIM 7250 Side Button Replacement, Battery: paso 1, imagen 2 de 3 Blackberry RIM 7250 Side Button Replacement, Battery: paso 1, imagen 3 de 3
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Blackberry RIM 7250 Side Button Replacement: paso 2, imagen 1 de 3 Blackberry RIM 7250 Side Button Replacement: paso 2, imagen 2 de 3 Blackberry RIM 7250 Side Button Replacement: paso 2, imagen 3 de 3
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Blackberry RIM 7250 Side Button Replacement: paso 3, imagen 1 de 3 Blackberry RIM 7250 Side Button Replacement: paso 3, imagen 2 de 3 Blackberry RIM 7250 Side Button Replacement: paso 3, imagen 3 de 3
    • Remove the battery from the compartment.
  4. Blackberry RIM 7250 Side Button Replacement, Back Housing: paso 4, imagen 1 de 2 Blackberry RIM 7250 Side Button Replacement, Back Housing: paso 4, imagen 2 de 2
    • Remove the four 10.7 mm Torx T6 screws.
  5. Blackberry RIM 7250 Side Button Replacement: paso 5, imagen 1 de 2 Blackberry RIM 7250 Side Button Replacement: paso 5, imagen 2 de 2
    • Remove the two 5 mm Torx T6 screws.
  6. Blackberry RIM 7250 Side Button Replacement: paso 6, imagen 1 de 1
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  7. Blackberry RIM 7250 Side Button Replacement: paso 7, imagen 1 de 3 Blackberry RIM 7250 Side Button Replacement: paso 7, imagen 2 de 3 Blackberry RIM 7250 Side Button Replacement: paso 7, imagen 3 de 3
    • Grab the back housing from the bottom and lift the housing away from you.
  8. Blackberry RIM 7250 Side Button Replacement, Front Housing: paso 8, imagen 1 de 2 Blackberry RIM 7250 Side Button Replacement, Front Housing: paso 8, imagen 2 de 2
    • Place your thumb on the bottom rectangle and your index finger on the top rectangle.
    • Squeeze your fingers together to release the internals from the front housing.
  9. Blackberry RIM 7250 Side Button Replacement: paso 9, imagen 1 de 3 Blackberry RIM 7250 Side Button Replacement: paso 9, imagen 2 de 3 Blackberry RIM 7250 Side Button Replacement: paso 9, imagen 3 de 3
    • Pull the two pieces apart to separate the front housing from the internals.
  10. Blackberry RIM 7250 Side Button Replacement, Side Button: paso 10, imagen 1 de 2 Blackberry RIM 7250 Side Button Replacement, Side Button: paso 10, imagen 2 de 2
    • Remove the single 5 mm Torx T6 screw.
  11. Blackberry RIM 7250 Side Button Replacement: paso 11, imagen 1 de 3 Blackberry RIM 7250 Side Button Replacement: paso 11, imagen 2 de 3 Blackberry RIM 7250 Side Button Replacement: paso 11, imagen 3 de 3
    • Grab side button housing with your thumb and index finger.
    • Remove the side button housing from the internals.
  12. Blackberry RIM 7250 Side Button Replacement: paso 12, imagen 1 de 3 Blackberry RIM 7250 Side Button Replacement: paso 12, imagen 2 de 3 Blackberry RIM 7250 Side Button Replacement: paso 12, imagen 3 de 3
    • Hold the side button housing with one hand and hold the side button with the other.
    • Lift the side button from side button housing.
    • There will be a subtle click when the side button is detached from the side button housing.
Conclusión
Noah Eckert
Miembro Desde 11/05/18
519 Reputación
5 Guías creadas
Equipo
IUPUI, Team S2-G4, Baechle Fall 2018 Miembro de IUPUI, Team S2-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G4
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 156
