Saltar al contenido principal
Blackberry Pearl 8100 SIM Card Replacement
  1. Blackberry Pearl 8100 SIM Card Replacement, Battery: paso 1, imagen 1 de 1
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. Blackberry Pearl 8100 SIM Card Replacement, SIM Card: paso 3, imagen 1 de 1
    • Slide the larger of the two metal casings upward (in the direction pointed to as “unlock”).
  3. Blackberry Pearl 8100 SIM Card Replacement: paso 4, imagen 1 de 1
    • Lift the metal casing.
    • Insert an SD Card.
Conclusión
2 personas más completaron esta guía.
Robert Cronin
Miembro Desde 04/08/10
544 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 34-57, Forte Spring 2010 Miembro de Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 9,282
