Saltar al contenido principal
Introducción
Follow this guide to install a SIM card in the Blackberry Pearl 8100.
Herramientas
No se especificaron herramientas.
Partes
No se especificaron partes.
  1. Before working on the phone, be sure that the phone is turned off. Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Before working on the phone, be sure that the phone is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  3. Slide the larger of the two metal casings upward (in the direction pointed to as “unlock”).
    • Slide the larger of the two metal casings upward (in the direction pointed to as “unlock”).
  4. Lift the metal casing.
    • Lift the metal casing.
    • Insert an SD Card.
Conclusión
2 personas más completaron esta guía.
Robert Cronin
Miembro Desde 08/04/10
520 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 34-57, Forte Spring 2010 Miembro de Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 17
Todo El Tiempo: 8,694
