Saltar al contenido principal
Blackberry Curve 9300 Screen Replacement
Qué necesitas
  1. Blackberry Curve 9300 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Screen Replacement: paso 2, imagen 1 de 1
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Screen Replacement: paso 3, imagen 1 de 1
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Screen Replacement, Keyboard: paso 4, imagen 1 de 1
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Screen Replacement: paso 5, imagen 1 de 2 Blackberry Curve 9300 Screen Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Screen Replacement: paso 6, imagen 1 de 1
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Screen Replacement: paso 7, imagen 1 de 1
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Screen Replacement: paso 8, imagen 1 de 1
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Screen Replacement: paso 9, imagen 1 de 1
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Screen Replacement, Screen: paso 10, imagen 1 de 1
    • Locate and remove the two 5mm screws on top of keyboard base using the T6 Torx screwdriver
  11. Blackberry Curve 9300 Screen Replacement: paso 11, imagen 1 de 1
    • Carefully pull the keyboard base up and away from the phone.
    • Disconnect the keyboard base from the phone completely.
  12. Blackberry Curve 9300 Screen Replacement: paso 12, imagen 1 de 3 Blackberry Curve 9300 Screen Replacement: paso 12, imagen 2 de 3 Blackberry Curve 9300 Screen Replacement: paso 12, imagen 3 de 3
    • Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Screen Replacement: paso 13, imagen 1 de 2 Blackberry Curve 9300 Screen Replacement: paso 13, imagen 2 de 2
    • Use a plastic opening tool to find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • The opening tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Screen Replacement: paso 14, imagen 1 de 2 Blackberry Curve 9300 Screen Replacement: paso 14, imagen 2 de 2
    • From the back of the phone, use a finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Screen Replacement: paso 15, imagen 1 de 3 Blackberry Curve 9300 Screen Replacement: paso 15, imagen 2 de 3 Blackberry Curve 9300 Screen Replacement: paso 15, imagen 3 de 3
    • Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard.
Conclusión
9 personas más completaron esta guía.
Alek Squires
Miembro Desde 09/30/13
431 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-7, Forte Fall 2013 Miembro de Cal Poly, Team 14-7, Forte Fall 2013
CPSU-FORTE-F13S14G7
5 Miembros
5 Guías creadas
Un comentario
would appreciate new ldc part # and order info! - - !
Donald Burgo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 4,750
