1. We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
    • We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
    • Hold the phone with the back side facing you.
    • Press down on the silver tab towards the bottom end of the phone.
    • Carefully lift up the back casing to reveal the battery.
  2. Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
    • Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
    • The phone should now look like this.
  3. Remove the two top screws using a T5 Torx screwdriver.
    • Remove the two top screws using a T5 Torx screwdriver.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  5. Use a plastic opening tool to pry the edges of the bottom cover until it snaps loose. The cover will now pull off easily.
    • Use a plastic opening tool to pry the edges of the bottom cover until it snaps loose.
    • The cover will now pull off easily.
  6. Use a plastic opening tool to pry between the front and back cover. Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
    • Use a plastic opening tool to pry between the front and back cover.
    • Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
    • There are 5 securing clips on the front panel to disconnect.
    • Pry gently to prevent breaking the plastic clips when removing the front panel.
    • Once all the clips have been freed, the front cover will lift away from the phone.
  7. Lift the flexible keypad away from the device. It should come off easily.
    • Lift the flexible keypad away from the device. It should come off easily.
  8. Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing. Lift the keyboard frame away from the device.
    • Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing.
    • Lift the keyboard frame away from the device.
    • There may be a small amount of adhesive at the bottom of the frame that needs to be pulled away.
Conclusión
Una persona más ha completado esta guía.
Nolan Reker
Miembro Desde 04/04/12
30 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-11, Forte Spring 2012 Miembro de Cal Poly, Team 14-11, Forte Spring 2012
CPSU-FORTE-S12S14G11
5 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,734
