Saltar al contenido principal
Blackberry Curve 8330 Battery Replacement
  1. Blackberry Curve 8330 Battery Replacement, Remove Back Cover: paso 1, imagen 1 de 1
    • We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
    • Hold the phone with the back side facing you.
    • Press down on the silver tab towards the bottom end of the phone.
    • Carefully lift up the back casing to reveal the battery.
  2. Blackberry Curve 8330 Battery Replacement, Remove Battery: paso 2, imagen 1 de 1
    • Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
    • The phone should now look like this.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 14-11, Forte Spring 2012 Miembro de Cal Poly, Team 14-11, Forte Spring 2012
CPSU-FORTE-S12S14G11
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 2,234
