Saltar al contenido principal
Blackberry Curve 8320 Keyboard Replacement
Qué necesitas
  1. Blackberry Curve 8320 Keyboard Replacement, Front Panel: paso 1, imagen 1 de 3 Blackberry Curve 8320 Keyboard Replacement, Front Panel: paso 1, imagen 2 de 3 Blackberry Curve 8320 Keyboard Replacement, Front Panel: paso 1, imagen 3 de 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  2. Blackberry Curve 8320 Keyboard Replacement: paso 2, imagen 1 de 2 Blackberry Curve 8320 Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  3. Blackberry Curve 8320 Keyboard Replacement: paso 3, imagen 1 de 2 Blackberry Curve 8320 Keyboard Replacement: paso 3, imagen 2 de 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  4. Blackberry Curve 8320 Keyboard Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  5. Blackberry Curve 8320 Keyboard Replacement: paso 5, imagen 1 de 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  6. Blackberry Curve 8320 Keyboard Replacement, Keyboard: paso 6, imagen 1 de 2 Blackberry Curve 8320 Keyboard Replacement, Keyboard: paso 6, imagen 2 de 2
    • Remove the keyboard.
    • Be careful not to bend or fold the keyboard, as it can break easily.
Conclusión
Una persona más ha completado esta guía.
Yegor Pomortsev
Miembro Desde 10/12/11
123 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-6, Regan Fall 2011 Miembro de Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 2,052
