Saltar al contenido principal
Blackberry Bold 9900 Trackpad Replacement
Qué necesitas
  1. Blackberry Bold 9900 Trackpad Replacement, Battery: paso 1, imagen 1 de 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Trackpad Replacement: paso 2, imagen 1 de 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Trackpad Replacement, MicroSD card: paso 3, imagen 1 de 2 Blackberry Bold 9900 Trackpad Replacement, MicroSD card: paso 3, imagen 2 de 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Trackpad Replacement, Keyboard: paso 4, imagen 1 de 2 Blackberry Bold 9900 Trackpad Replacement, Keyboard: paso 4, imagen 2 de 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  5. Blackberry Bold 9900 Trackpad Replacement: paso 5, imagen 1 de 2 Blackberry Bold 9900 Trackpad Replacement: paso 5, imagen 2 de 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  6. Blackberry Bold 9900 Trackpad Replacement: paso 6, imagen 1 de 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  7. Blackberry Bold 9900 Trackpad Replacement: paso 7, imagen 1 de 2 Blackberry Bold 9900 Trackpad Replacement: paso 7, imagen 2 de 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  8. Blackberry Bold 9900 Trackpad Replacement, Trackpad: paso 8, imagen 1 de 3 Blackberry Bold 9900 Trackpad Replacement, Trackpad: paso 8, imagen 2 de 3 Blackberry Bold 9900 Trackpad Replacement, Trackpad: paso 8, imagen 3 de 3
    • Push into the trackpad. This will release the trackpad supporting piece.
  9. Blackberry Bold 9900 Trackpad Replacement: paso 9, imagen 1 de 2 Blackberry Bold 9900 Trackpad Replacement: paso 9, imagen 2 de 2
    • The trackpad is attached via ribbon cable. Pull this cable up in order to release the trackpad.
Conclusión
Chris Velasquez
Miembro Desde 01/30/18
214 Reputación
2 Guías creadas
Equipo
Baylor, Team S1-G4, Johnson Spring 2018 Miembro de Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 1,033
