Saltar al contenido principal
Blackberry Bold 9900 Memory Card Replacement
  1. Blackberry Bold 9900 Memory Card Replacement, Battery: paso 1, imagen 1 de 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Memory Card Replacement: paso 2, imagen 1 de 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Memory Card Replacement, MicroSD card: paso 3, imagen 1 de 2 Blackberry Bold 9900 Memory Card Replacement, MicroSD card: paso 3, imagen 2 de 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Memory Card Replacement, Mini-SIM removal: paso 4, imagen 1 de 1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
Conclusión
Una persona más ha completado esta guía.
Sowmika
Miembro Desde 01/30/18
253 Reputación
2 Guías creadas
Equipo
Baylor, Team S1-G4, Johnson Spring 2018 Miembro de Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 921
