Saltar al contenido principal
Blackberry Bold 9650 Faceplate Replacement
Qué necesitas
  1. Blackberry Bold 9650 Faceplate Replacement, Battery: paso 1, imagen 1 de 2 Blackberry Bold 9650 Faceplate Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Faceplate Replacement: paso 2, imagen 1 de 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Faceplate Replacement, SIM Card: paso 3, imagen 1 de 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Faceplate Replacement: paso 4, imagen 1 de 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Faceplate Replacement, Back Chassis: paso 5, imagen 1 de 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Faceplate Replacement: paso 6, imagen 1 de 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Faceplate Replacement: paso 7, imagen 1 de 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Faceplate Replacement: paso 8, imagen 1 de 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Faceplate Replacement, Mother Board: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Blackberry Bold 9650 Faceplate Replacement: paso 10, imagen 1 de 1
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Blackberry Bold 9650 Faceplate Replacement: paso 11, imagen 1 de 1
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Blackberry Bold 9650 Faceplate Replacement: paso 12, imagen 1 de 1
    • Remove the mother board by lifting the board upward.
  13. Blackberry Bold 9650 Faceplate Replacement, Faceplate: paso 13, imagen 1 de 2 Blackberry Bold 9650 Faceplate Replacement, Faceplate: paso 13, imagen 2 de 2
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
Conclusión
2 personas más completaron esta guía.
Ryan
Miembro Desde 03/12/12
696 Reputación
11 Guías creadas
Equipo
Clemson, Team 2-5, Benson Spring 2012 Miembro de Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 2,409
