Saltar al contenido principal
Blackberry Bold 9000 Volume Toggle Replacement
Qué necesitas
  1. Blackberry Bold 9000 Volume Toggle Replacement, Battery: paso 1, imagen 1 de 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Volume Toggle Replacement: paso 2, imagen 1 de 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Volume Toggle Replacement: paso 3, imagen 1 de 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Volume Toggle Replacement, Rear Case: paso 4, imagen 1 de 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Volume Toggle Replacement: paso 5, imagen 1 de 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Volume Toggle Replacement: paso 6, imagen 1 de 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Volume Toggle Replacement, Volume Toggle: paso 7, imagen 1 de 1
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Volume Toggle Replacement: paso 8, imagen 1 de 1
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  9. Blackberry Bold 9000 Volume Toggle Replacement: paso 9, imagen 1 de 1
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
Conclusión
2 personas más completaron esta guía.
Kelly
Miembro Desde 01/18/12
566 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 8-17, Maness Winter 2012 Miembro de Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 2,445
