Saltar al contenido principal
Blackberry Bold 9000 Trackball Replacement
Qué necesitas
  1. Blackberry Bold 9000 Trackball Replacement, Battery: paso 1, imagen 1 de 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Trackball Replacement: paso 2, imagen 1 de 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Trackball Replacement: paso 3, imagen 1 de 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Trackball Replacement, Rear Case: paso 4, imagen 1 de 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Trackball Replacement: paso 5, imagen 1 de 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Trackball Replacement: paso 6, imagen 1 de 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Trackball Replacement, Trackball: paso 7, imagen 1 de 1
    • Using the same plastic opening tool, lift out the motherboard assembly.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Trackball Replacement: paso 8, imagen 1 de 1
    • Using a spudger, pry the top of the metal casing off. There are two pins holding it in place; it should pop off easily.
    • Repeat to the bottom.
    • This step requires pristine dexterity. Try to find a friend with smaller fingers if necessary.
  9. Blackberry Bold 9000 Trackball Replacement: paso 9, imagen 1 de 1
    • Lift the trackball out of its socket.
Conclusión
5 personas más completaron esta guía.
Kelly
Miembro Desde 01/18/12
566 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 8-17, Maness Winter 2012 Miembro de Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 11,182
