Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Partes
No se especificaron partes.
  1. Place your Blackberry facedown in front of you.
    • Place your Blackberry facedown in front of you.
  2. Press the cover release button on the bottom of your device. Lift and remove the back cover.
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. From the top, use your fingernail to lift the battery out.
    • From the top, use your fingernail to lift the battery out.
  4. Remove the SIM card.
    • Remove the SIM card.
  5. Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Use the plastic opening tool to remove the rear case.
    • Use the plastic opening tool to remove the rear case.
Conclusión
2 personas más completaron esta guía.
Kelly
Miembro Desde 18/01/12
566 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 8-17, Maness Winter 2012 Miembro de Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 3,029
